Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: AE86 Camber Tops Caster?
  1. #11
    Senior Member ToySprinta's Avatar
    Steve
    Padstow
    What if you swap the tops side to side, just put an ae86 front end in an AE71, and noticed if you swap the tops left to right, it would change the castor...
  2. #12
    yeh more castor = hevier steering. + straight line stability...
    they put it into powersteering setups because it doesnt worry the driver about how heavy it is, cos of pas, + you get the stability
    toysprinta=== ive seen that done on a japcresta.. they switched side to side so wen you adjusted camber you also adjusted castor... i think? it was at an angle if you no what i mean
    EDIT - here it is... speedhunters.
  3. #13
    Veteran bigm's Avatar
    Gold Coast
    thats is interesting?
    can you have to much caster?
  4. #14
    i just got my camber tops....
    part number 116 410 FIA
    are these the ones i want for my ke70....ie good castor model....
    or do i want
    part number 116 410 A
  5. #15
    Veteran Konakid's Avatar
    Henry
    Eastern
    116 410FIA
    The high castor type.
  6. #16
    Jonathan
    Yes and no.
    4A-C and 3A-U with P/S do have the high caster ones.
    4A-C and 3A-U normaly have low caster ones.
    But all 4A-GE models had the high caster ones, with or without P/S.
  7. #17
    alrite.. i was just a little confused because the site stated them as std castor.
  1. WTB: ae86 camber tops/ camber plates
    By ae8620v in forum Cars or Parts Wanted
    Last Post: 12th August 2010, 09:29 PM
  2. AE86 Camber Tops
    By Monk in forum Car Parts For Sale
    Last Post: 26th August 2008, 06:51 PM
  3. ae86 camber tops
    By Trucka 115 in forum Cars or Parts Wanted
    Last Post: 4th July 2007, 10:11 PM
  4. ae86 camber tops
    By spoon in forum Cars or Parts Wanted
    Last Post: 27th December 2006, 09:20 AM
