Results 1 to 5 of 5
Thread: length of trailing arm bolt
    Glenn ke_70's Avatar
    Clay
    Barossa!
    Default length of trailing arm bolt
    hey just bored at work and want to know the length of the trailing arm bolts so i can grab some new ones before i have to go home
    Clay
    Barossa!
    3'' is the one
    Moderator Sam-Q's Avatar
    Endeavour Hills
    like new from a bolt store? I wouldnt suggest it as the ones from factory have a specific shank length and if you buy ones from a bolt store they will almost without a doubt end up resting on the threads at one end0. I know it probably won't make much of a difference in the rear world but it's a good practice to avoid sheared bolts and extra slop. With a rod end trailing arm it might even make a knocking sound.
    Clay
    Barossa!
    i have one to suit with the correct shank but thanks for the concern sam :p
    Endeavour Hills
    ah good, no probs
  1. Trailing Arm Troubles
    By svenmate in forum Technical - Questions
    Last Post: 29th August 2010, 10:33 AM
  2. Trailing arm bush options
    By starni_boy in forum Technical - Questions
    Last Post: 5th April 2010, 01:44 PM
  3. Stiffer trailing arm bushes ?
    By fixeruperer in forum Technical - Questions
    Last Post: 28th October 2009, 10:10 PM
  4. HELP upper trailing arm
    By i2obert in forum Technical - Questions
    Last Post: 10th October 2009, 01:48 PM
  5. length of upper and lower trailing arms
    Last Post: 16th August 2007, 05:12 PM
