Results 1 to 10 of 15
Thread: FS WA:bulletproof 4agte build partout!
    May 2010
    matt
    wa
    SOR
    Default FS WA:bulletproof 4agte build partout!
    ok well i have been collecting parts for my planned bulletproof 4agte build, but plans have changes, and i would rather spend the cash on my bike. so i have the following parts for sale! i am asking very reasonable prices for all these as i would like them gone quickly, but don't expect a reply if you make a stupid offer.
    -ROSS RACING PISTONS - .020" (.5mm) oversize forged piston set. includes forged slugs, pins and top seal rings. still in wrapped up in box
    $500
    -BIGPORT HEAD-. has been fully serviced and prepped. Including sandblasted, faced, new valve seats with 3 angle grind on valves and seats. fitted with performance springs (that's the company name in qld) valve springs. Comes with standard cams fitted. all clearances have been set, just needs to be bolted on and cam timing set. Comes with supercharged cam covers powdered coated yellow. has not been fitted/used since rebuild.
    $500
    -EXEDY HD clutch. comes with pressure plate and friction plate. bought of a fellow forum member who had it in for a few dyno runs before replacing it.
    $150
    -TURBO SETUP- Custom 316 low mount stainless manifold (not cheap ebay shit). Comes with hks 2510 turbo, fittings, oil lines, and a v band dump attachment (dont exactly know what this is called but bolts to the exhaust housing and has v band flange which dump pipe then bolts too.
    $700
    -CATCH CAN-Petersen fluid systems baffled catch can. a proper catch can! not a glorified milo tin.
    $120
    -Celica ST205 GT4 4 piston brakes- These are huge! where 315mm x 32mm, but have been machined down too 300mm to fit my mr2. also the locating center diameter has been machned out and bushed to fit mr2 locating hub. come with lines, top secret pads, discs and yellow calipers
    $600
    - standard sump. sandblasted and powder coated black. $50
    -ACL rebuild kit. comes with every seal and gasket needed for a full motor rebuild. is missing valve stem seals as these were used in my cylinder head rebuild.
    $180
    -Liberty W2A intercooler setup. comes with intercooler, heat exchanger and pump. good condition.
    $300
    NEW PARTS ADDED
    - 4AGZE intake setup, including SC12 blower, intake manifold with all sensors, TB etc etc
    $300
    -4AGZE conrods. Have been deburred and polished. standard bolts removed
    $100
    im sure i have some more stuff but thats all i can think of right now.
    best place to contact me is on my mobile 0415782112
    matt
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    Location?
    May 2010
    matt
    wa
    SOR
    secret harbour, WA
    Nathan
    Lilydale
    any specifications on the pistons? dish type/any valve releifs/ compression ect.
    May 2010
    matt
    wa
    SOR
    sorry my bad! 8.5:1 CR. Has reliefs for valves
    Preston
    Wellard
    what size clutch?
    200mm? 215mm?
    May 2010
    matt
    wa
    SOR
    everything was to suit 4agze, so i actually think its 220mm
    Preston
    Wellard
    Thats what i thought.
    No worries.
    Reeece
    Casula
    Have you got receipts for the work done on the head?
    May 2010
    matt
    wa
    SOR
    yes i do mate. also new parts added
  1. 4AGTE Keto Build.
    By milto in forum KE70 / AE71 Owners Forums
    Last Post: 6th August 2012, 12:26 PM
  2. Replies: 5
    Last Post: 3rd February 2011, 11:08 PM
  3. Replies: 1
    Last Post: 3rd November 2010, 09:19 AM
  4. 4AGTE Build Specs
    By orangechargd86 in forum Technical - Articles
    Last Post: 27th March 2008, 11:10 PM
