Im pretty sure it is the mechanism in them that is worn out, im not even sure if you can replace them? I put genuine seals into them so that marks them off and the shop loosened the cables then re-adjusted them....but with no luck.
The question is...can you replace the mechanisms ha?
Thanks for your help mate
