Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: [SYD] New HSD Coil-over kit, Twin piston brakes, XT130 arms, custom knuckles +more
    Veteran keiichi's Avatar
    Zac
    Sunnybanku
    Wink [SYD] New HSD Coil-over kit, Twin piston brakes, XT130 arms, custom knuckles +more
    Located in East Balmain, basically everything you need to make coil-overs minus shox based on XT130 front end gear with a steering and brake upgrade.
    Can post at buyers expense.
    1. New unused, package only opened to inspect, HSD coil-over kit includes 51mm steel threaded sleeve, 8kg/mm springs, adjusting spanners, helper springs, top hats with pilot holes etc.
    2. XT130 bare strut completely stripped down just needs to be grinded, cleaned and shortened to suit the shox you use. comes with bearings, nuts, bolts and the rotor. (also have xt130 standard calipers and strut top mount if someone wants them make an offer)
    3. Twin piston calipers to suit above rotors, good but dirty condition. Could use some new pads (about 5-10mil of meat left).
    4. XT130 LCA's with new super pro bushings already pressed in. Good but dirty condition, does NOT need new ball joints. Will chuck in some longer tie rod ends to suit.
    5. Custom cut'n'shut heyman style steering knuckles to suit XT130 strut (and ae86 i think?). the design of these is great as they serve three purposes... they lower the mounting point for your tie rods, increase lock, and reduce ackerman angle. Welded and x-rayed for strength, got these off a guy in melbourne who had another pair running on his car.
    1. SOLD
    2. SOLD
    3. $150
    4. SOLD
    5. SOLD
    PM, Post or you can call me on 0431 962 633
    Zac
    Member JDMBenji's Avatar
    Camperdown
    how much for the Xt130 LCA's posted to QLD 4559? Cheers =)
    Zac
    Sunnybanku
    Hey there,
    I'm sure it wouldn't be anymore than $20 but I'll confirm that for you tomorrow.
    Zac
    Sunnybanku
    express post 5kg parcel is 18.50 normal post should be about $14
    Camperdown
    They'll go on an 86 nicely won't they? =) Howd you want payment? Ben
    Zac
    Sunnybanku
    yep theyll give you a little extra camber and track plus you got urethane in there.
    i prefer direct bank deposit, im a trusted seller and long term member of this site, ill pm you my details... soon as it clears ill send it your way, pm me your postage details soon.
    Zac
    Sunnybanku
    pictures added and small price + content edit
    Zac
    Sunnybanku
    page four already? unacceptable.
    Zac
    Sunnybanku
    bump it
    Zac
    Sunnybanku
    price edit
  1. s13 HSD coilovers brakes and control arms FS SYD
    By OMG866 in forum Car Parts For Sale
    Last Post: 24th November 2012, 11:04 AM
  2. Replies: 1
    Last Post: 22nd March 2012, 08:49 PM
  3. Replies: 18
    Last Post: 5th December 2011, 11:48 PM
  4. [VIC] XT130 twin pot struts with brakes‏
    By KE70 in forum Car Parts For Sale
    Last Post: 25th September 2010, 02:30 PM
  5. Replies: 10
    Last Post: 2nd August 2010, 12:22 PM
