Results 1 to 8 of 8
Thread: GZE to work with my Sprinters Tacho
    Senior Member PRIMRK's Avatar
    Dec 2009
    Cameron
    Brighton
    Default GZE to work with my Sprinters Tacho
    I've got an ADM sprinter with a 4AGZE in it, it runs and everything works apart from the tacho.
    What is needed to make this work? and what wires need to go where?!?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    did you do a search?
    Dave
    a few seconds on the google machine revealed this:
    - Blaise Pascal
    Endeavour Hills
    theres more in this forum as well, this subject comes up often. Please search next time
    Dec 2009
    Cameron
    Brighton
    Is there a dif between the JDM and ADM clusters?
    The first link is for a JDM cluster and just dont want to pull it out and find if its differant?!?
    Dec 2009
    Cameron
    Brighton
    Sorry but whenever i search forums (not just this one) it will come up with flood control most the time, it works every now and then but i think there must be somehtig in my interwebs settings
    Veteran shift_rook's Avatar
    SE Burbs
    why are people so pissy when it comes to searching? you could have answered the question and closed the thread instead of complaining they didn't use the search button, can't help you with this though dude
    Veteran Skylar's Avatar
    Ken
    If people would search, you wouldn't have a hundred threads about the same thing. You'd have one or two comprehensive threads that have been dug up multiple times with EVERYTHING you need to know in them.
    It's like people don't even try anymore because they know the internet will hand them the answers when they ask when you could use your brain just a tiny bit and google it or even go out to the car and try it.
    Regarding tacho's of jap and aus cars: Why would they be different? Both do the same thing from the same signal. The only difference is the face panel showing different redlines.
  1. Help with getting tacho to work in ae86
    By Dre86 in forum Technical - Questions
    Last Post: 4th November 2011, 08:05 AM
  2. Tacho doesn't work
    By tomasS in forum Technical - Questions
    Last Post: 3rd June 2010, 01:20 PM
  3. Getting my stock tacho to work
    By Trumps in forum Technical - Questions
    Last Post: 27th June 2008, 08:28 AM
  4. getting tacho to work
    By DRiiFT_King in forum Technical - Questions
    Last Post: 20th October 2006, 02:20 PM
