Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: ae86 trueno headlights dieing
  1. #11
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    haha will try to champ, going to get dads mate to look at it when hes free, found a thread on here repairing ae86 headlight switch ? steps sound like alot of headfucks taking dash appart
  2. #12
    Jay
    it sounds hard but its actually really easy will take a second to take it apart, dont even need to take the dash facia out , you can just slip the switch out the side of it
    Rust is a way of life
  3. #13
    May 2010
    Derryl
    CA
    Napa Valley
    United States
    i had the same problem except with my dash lights, it was a broken wire.
  4. #14
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Had a similar issue with both my rear lights and headlight motors in my trueno.
    Both instances the solder joints were cracked.
    I just cleaned up the board with contact cleaner, re-heated, and added a little more solder.
    Haven't had any issues as yet.
    As others have said above, its probably the switch and a similar cracked solder joint issue.
  5. #15
    Senior Member aaron's Avatar
    Aaron
    NOR
    can you give the link for that thread please with the steps. had a browse but couldn't find it
    83' 4AGTE Hachi - 335whp @ 22psi on United E85.
    Never ending build...
  6. #16
    Dave
    Western Suburbs
    try google then,
    tried wifebeating the dash a bit with the palm of my hand, no flashes or any signal of other light coming on... still unsure if i should go through with pulling it apart cause i swear i could remember playing with the wiring right @ the root of the headlights when the low beams first died and you could move it a little up there and they would flicker on
  7. #17
    Jay
    just take the switch out its easy as, will take a second to solder all the joints in, just make sure you solder all the pins on the inside of the switch , and also make sure you dont lose the little ball bearing in side the switch which holds it in place as you click it as that what happened to me and now my switch doesnt click into place
  8. #18
    Dave
    Western Suburbs
    fixed the issue, wasnt switch was the globes, low beam was kind of dead on drivers side now passenger side LOL that bulb was fkt was black ?! and was swollen had a fetus on the side,
    <3 10000k hids.
  1. Oem trueno front guards and trueno pop up headlights
    By 86-VTEC in forum Cars or Parts Wanted
    Last Post: 24th November 2012, 07:50 PM
  2. Trueno Pop up Headlights
    By briigo82 in forum Technical - Questions
    Last Post: 7th May 2012, 07:24 PM
  3. Have you seen these Trueno headlights before?
    By jet111 in forum General Topics (No Technical Questions)
    Last Post: 30th December 2010, 02:30 PM
  4. zenki trueno headlights bulbs
    By slippry in forum Technical - Questions
    Last Post: 10th July 2007, 03:48 PM
