Results 1 to 10 of 11
Thread: Question regarding Intake Air Temperature Sensor (IAT)
    Apr 2010
    Michael
    Cebu City
    Cebu
    Philippines
    Default Question regarding Intake Air Temperature Sensor (IAT)
    Where is this sensor located? A pic would be very helpful.
    1983 Toyota Corolla GT Model
    Moderator Sam-Q's Avatar
    Endeavour Hills
    well which engine?
    Jonathan
    Show us a pic of your engine bay first, or say what motor you have.
    Apr 2010
    Michael
    Cebu City
    Cebu
    Philippines
    4age 20v bt
    Jonathan
    The air temp sensor would have been in the air filter box, which you don't have. However you can easily find one from any regular AE112R-ALMDKQ or similar Corolla.
    Endeavour Hills
    most people in your position attach it to the strut tower
    Apr 2010
    Michael
    Cebu City
    Cebu
    Philippines
    Jonny - I see. I do have an airbox. Just couldn't find it. Thanks.
    SamQ - I'm going for open ITB setup. So i just place the iat sensor in the strut tower or anywhere in the engine bay?
    Endeavour Hills
    the closer you can get it to the opening to your trumpets the better. I guess off a strut brace would be ideal but the strut tower will be the next best thing.
    Are you going to put filters on that?
    Apr 2010
    Michael
    Cebu City
    Cebu
    Philippines
    Just bought this a minute ago, is this the IAT sensor for my 20v BT?
    I also have a question regarding the O2 sensor. A friend told that the 20v O2 sensor heats up when the engine is running (O2 sensor not yet planted on the headers) is this true?
    Jonathan
    Yes, your picture is of a air temp sensor. It is a variable resistor and has 2 wires. You can place it where ever you like. The water temp sensor also works in the same way, but looks different.
    A 4 wire O2 sensor has it's own heater. A 1 wire O2 sensor does not. You can probably use either.
    If you are using the Toyota ECU, you probably want as many of the sensor hooked up as you can.
    If you are using a programable ECU, you need a minimum of CAS, TPS and water temp hooked up.
  1. 4age intake air sensor thread size?
    By Wyma in forum Technical - Questions
    Last Post: 18th April 2012, 09:46 PM
  2. Replies: 0
    Last Post: 2nd August 2010, 02:24 PM
  3. 4agze Accel cable mount, 4agze ae101 air intake temp sensor
    By Roo. in forum Cars or Parts Wanted
    Last Post: 13th May 2009, 07:00 PM
  4. Bigport Air Intake Temp Sensor
    By Golberg in forum Cars or Parts Wanted
    Last Post: 3rd October 2008, 10:53 AM
  5. WTB standard air box / cold air intake
    By snake in forum Cars or Parts Wanted
    Last Post: 2nd June 2008, 10:06 PM
