hey guys,
have a head scratcher im not working out.
Have - brand new hsd ae86 coilovers for the front
brand new t3 big brake kit
ae86 hubs
new bearings
ae86 backing plates with dust shield cut off
When i go to put all the bits together, the brake rotor hits EVERYTHING. if i get the hub anywhere near fitting, the rotor is rubbing on the front face of the caliper mount and thats without the t3 adaptor braket installed. Its like the stub is 25mm to short or something?
have installed the bub bare and it seems to work fine, the bearings were ae86 bearings from repco and looked the same as the ones that came out, when done up the hub shows no signs of wobbling, so i think the hub is right and ae86.
the backing plates appear to only go on one way, and he bolts all line up on that...
its got me humped and i cant continue with my daily till its sorted .....
i had a look at the replace bearings and rotors tech article also and eerything looks about the same.....
any help would be muchly appreciated.
