Results 1 to 10 of 11
Thread: need help diagnosing a problem
    Member sdrawkcab's Avatar
    Ash
    Default need help diagnosing a problem
    i have a really high pitched squeal when i put on about 1/2 to 3/4 throttle. i have 20v trumpets and at first i thought it may have been noisy injectors but it seems a bit loud and constant to be that. maybe a rooted bearing? any ideas guys?
    '84 zenki trueno, red panda, blacktop 20 valve, ssr longchamps.
    Gone
    Joel
    Picton
    check the tension on the drive belts... or fan belts whatever u want to call them
    Ash
    Cheers mate, I'll have a look.
    Veteran driftke70's Avatar
    Ryan
    Buderim
    air leak somewhere, if its throttle related its unlikely to be something mechanical unless your alternators fucked
    past that maybe cam belt tensioner
    wheelfriends.wordpress.com
    Ash
    Checked the belts no problems there. What's the easiest way to check for an air leak then?
    Dave
    i dont think it would be an airleak causing the problems.
    air leaks will make noise at low throttle positions, since vacuum is higher etc.
    unfortunately its pretty hard to diagnostic, wanna take a video? chuck it up on youtube?
    - Blaise Pascal
    Ash
    ill give it a go. might not hear it over the other noises lol, the iphone doesn't have the best camera
    Jonathan
    Go back and tighten the belts anyway.
    Or to diagnos the noise, spraw WD40 on the belts while then engine is squeeling and making the noise. If the noise suddenly stopps, you know its the belts.
    Ash
    Videos are a no go. Crappy iPhone mic didn't pick up the noise over my mad induction lol. I'll try the wd40 option. Btw I was wrong about when the noise kicks in, at around 10% throttle it starts and goes away around 25. Oh and it only does it when im driving sounds fine when I rev it parked? Sorry about that I haven't had the chance to drive it since I first posted.
    Senior Member dtour's Avatar
    Jun 2009
    Jon
    Ryde
    both my first and second silvertop made/make this noise(sqeaky sort of whistle?), i think its just wat the quads sound like at those throttle positions when under load.
  1. about ecu problem
    By dasini in forum Technical - Questions
    Last Post: 15th January 2011, 04:13 PM
  2. SR wont start - need help diagnosing it
    By Simon-AE86 in forum Technical - Questions
    Last Post: 19th July 2008, 07:47 PM
  3. problem
    By callum1 in forum General Topics (No Technical Questions)
    Last Post: 3rd May 2007, 08:48 PM
  4. what could this problem be?
    By callum1 in forum Technical - Questions
    Last Post: 17th February 2007, 10:50 AM
