Results 1 to 10 of 10
Thread: ignition barrel removal :)
    Senior Member Drift_Donkey's Avatar
    Byron
    Default ignition barrel removal :)
    how to hell do u take an ae86 ignition barrel out. I tried undoing all bolts to remove whole unit from steering colum. but it still wont come loose. any help please.
    even if you could come do it for me or show me how. Im located nrth nsw. Pottsville
    Quote Originally Posted by marvis View Post
    I also like sportmaxx and incorrectly placed/applied hangrings.
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Just the barrel/cylinder?
    Insert key, Turn to 'on' position.
    With the cover off, if you look at the top of the barrel there is a hole. In that hole is a pin. Push it down with a small drill bit, screwdriver, or whatever you have handy.
    It'll slide right out.
    Andrew
    Byron
    The reason i need to barrel out is to get a key cut should have mentioned that in last post. so i cant put a key in it
    if you dont have a key you will have to drill out the pin and then the barrel will slide out
    Dave
    just take your drivers door barell to get a key cut.
    they only need to read the code off the barell too. and look it up in their computer.
    - Blaise Pascal
    Byron
    Drivers side door has been shaved i got a key cut from passenger side but must be a different lock. I tried to remove the whole unit from the steering colum but it wont budge. So will I have to actually drill the pin out?
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Might as well just unbolt the whole steering column and take it to the guy. If you have a hatch/trunk lock still you can have him match the key to it.
    You drill it out, and you will have to buy a new lock cylinder.
    Andrew
    Byron
    Yeh I think the whole thing is attached to the steering collum.
    Gayer than AIDS.....$150 for a key as i have to get a mobile locksmith.
    FML
    Senior Member DearmanKE's Avatar
    Alex
    Northfield
    dunno about 86's but with my ke70 one i took it off without pshing any pins in, there were just a few screws at the back of it holding it and a circlip at the front
    Formerly known as grape_moosha
    Tan
    West
    pin is right, done it twice and its a pain especially because the barrel casing is cast and very soft. I used a small screw driver to lever the barrel out as well as trying to hold the pin down.
  1. Ignition barrel
    By luke__ in forum Technical - Questions
    Last Post: 20th December 2012, 10:36 AM
  2. what wires do what on ke70 ignition barrel?
    By 70wagon in forum Technical - Questions
    Last Post: 8th November 2009, 07:59 PM
  3. ke70 ignition barrel
    By sonsta in forum Technical - Questions
    Last Post: 18th September 2009, 11:56 AM
  4. Ignition Barrel.
    By dish in forum Technical - Questions
    Last Post: 15th April 2006, 09:04 PM
