Results 1 to 5 of 5
Thread: 4age bigport idle/fuel issues
    May 2010
    Glen waverly
    Default 4age bigport idle/fuel issues
    Hey guysc got a bigport that usually idles around 1500, seems a bit high but no matter how much I back the idle screw it doesn't change
    also it's going through roughly 300km per tank, but only letting me fill 40 litres, only shows 3/4 tank when I fill it.
    Aaaaalso on top of my intake manifold I noticed a vacuum hose that goes in a small loop into the vacuum port next to it, seen a pic of someone elses bigport and theirs went somwhere (will post pic shortly)
    engines a jap spec genuine rwd bigport if this helps (dropped in an adm 86)
    Moderator Sam-Q's Avatar
    Endeavour Hills
    have you checked if you have a fault code?
    May 2010
    Glen waverly
    Noob here, I'll see if I can find out how to check
    Dave
    you will need to hook up the check engine light to check the codes.
    just grab a bulb, stick 12V on one side of it, and connect the other side to the check engine pin on your ecu.
    that fuel usage is pretty damn high!
    check those ecu codes, mine was doing something simliar and it turned out to be the coolant temp sensor.
    - Blaise Pascal
    May 2010
    Glen waverly
    Thanks for the quick responses, I think a diy ecu check is a little out of my league, any other possibilities/checks you guys can think of?
  1. Replies: 2
    Last Post: 2nd September 2012, 08:44 PM
  2. Need bigport 4age fuel rail
    By captain_awesome in forum Cars or Parts Wanted
    Last Post: 14th June 2011, 11:26 AM
  3. idle issues
    By ae86 in forum Technical - Questions
    Last Post: 22nd July 2009, 08:05 PM
  4. wtd: 4AGE bigport fuel rail.
    By GZE KE70 in forum Cars or Parts Wanted
    Last Post: 12th March 2007, 11:14 PM
  5. 4kc idle issues
    By ke70dave in forum Technical - Questions
    Last Post: 22nd November 2006, 08:17 PM
