Results 1 to 3 of 3
Thread: tacho needle interference
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    Default tacho needle interference
    hey all in my trip to japan i found myself a defi tacho installed sweet now the problem i face is this when under heavy load at around 5000 rpm the needle starts to jump up and around 9000 rpm now i think this is interference with something now this is what i have thaught about
    -stock guage is still wired up interference from that?
    -coil playing silly
    -dizzy playing silly
    -aftermarket ecu givving funky readings or signal to coil
    now does anyone know of a line filter i can hook up to smooth out the interference
    thanks all
    mat
    the dyno pull to 300rwkw
    Mathew
    Sutho Shire
    so nobody knows of an inline filter to go between my gauge and my coil?
    Tan
    West
    I'm bit rusty with this but you could try 100ohm and 100nF ceramic cap and increase/decrease accordingly. Otherwise use a RC filter calculator for more accurate
    30-400Hz range is what you are working with for rpm.
  1. blacktop 20 valve 4age, Interference engine?
    By _sawyer_ in forum Technical - Questions
    Last Post: 12th February 2011, 11:16 AM
  2. no tacho
    By Faceplant456 in forum Technical - Questions
    Last Post: 19th April 2010, 08:29 PM
  3. speedo needle bouncing
    By BLIPAE86 in forum Technical - Questions
    Last Post: 26th September 2009, 10:08 PM
  4. Interference and non interference.
    By greenmac80 in forum Technical - Questions
    Last Post: 14th July 2009, 01:07 PM
  5. Wheel alignment Qn - interference between LCA and rod ends
    By skit in forum Technical - Questions
    Last Post: 22nd March 2008, 11:20 PM
