Results 1 to 10 of 16
Thread: blow by
    Veteran johl's Avatar
    Johl
    Default blow by
    so i was looking at a new 86 with a 16 valve in it yesterday and it was all sweet except the bloke said that it was going through a bit of oil. he had a hose coming from the back of the cam cover with a one way pressure valve on the end that would vent once it reached a certain pressure.
    i'v done a bit of research on the whole pcv thing and its still a bit cloudy. he said he would take it to a mechanic to have it looked at but i was just wondering if anyone thinks there may be an underlaying issue here. as far as im aware i could just fit in a catch can to take up the bad oil? or would it be a problem with the valve stem seals? btw he just spent $1200 on rebuilding the head.
    an help would be great before i go further on this car
    Veteran blair's Avatar
    Blair
    SEQ
    Could have poo'd rings. Compression test it.
    Ok
    Seamus
    Milton
    Almost definitely the rings then (if his head has been done)
    Johl
    Makes sense. I did see a bit of smoke coming out of the exhaust.
    Veteran shift_rook's Avatar
    SE Burbs
    yeah man, most likely ring, if that's the case do a comp test and appropriate lowballing that follows
    Johl
    will do. thanks guys.
    anyone replaced rings in their 4a recently? approx price?
    Penrith
    i do rebuilds all the time.could be looking any thing from $1000 and up.sometimes depending on your cash flow can be much cheaper to replace the engine.i have plenty of engines to choose from. drop me a line 0414 531 273.
    Ok
    Seamus
    Milton
    Couple of hundred, give or take.
    There's a guy in brissy called 'Mick Cashell Engines' or something along those lines, and he specialises in supplying rings for anything. But basically any good engine shop can get you something.
    Veteran Skylar's Avatar
    Ken
    One set of hastings rings I bought were $85. Endurotec pistons + hastings rings were 195. Then add to that the cost of a gasket set, maybe bearings if you feel like it/see the need for them. and while it's apart lets put forgies in it for turbo, maybe get rods, get the bearings coated if they already aren't, get a oil drain put in the sump and by now it's sorta cheaper to throw in a replacement engine. but you don't know how long it will last.
    A general rebuild (bore + new pistons, bearings, gasket set, tank the block, face the deck) ended up costing me about a grand but you know it'll last forever now. It's all clean and not fucked up, like some import engines.
    Taylor
    Parkwood
    was that car in fingal?
  1. it will blow your mind
    By stx-16 in forum Offtopic Discussions
    Last Post: 27th January 2010, 02:23 PM
  2. oil blow by hoses
    By slidin 86 in forum Technical - Questions
    Last Post: 22nd August 2008, 06:00 PM
  3. Why did my diff blow? :P
    By Robo86 in forum Technical - Questions
    Last Post: 26th May 2008, 09:59 PM
  4. blow through setup
    By **chumps** in forum Technical - Questions
    Last Post: 20th December 2007, 06:20 PM
  5. How do blow up your drivetrain for dummies.
    By PULSE in forum Offtopic Discussions
    Last Post: 20th August 2005, 01:45 AM
