Results 1 to 6 of 6
Thread: Brake lights and reverse lights not working
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Default Brake lights and reverse lights not working
    So I took my 81 panelvan for a blue slip and failed on brake lights and reverse lights not working.
    Now ive checked the fuse, brake switch is working and I've changed the bulbs, still nothing.
    The tail lights work it's just no brake lights and no reverse lights.
    Is there an earth somewhere on it?
    And any ideas of what to check next?
    Paul
    Maidstone
    check the plugs on the gear boxs .... for reverse lights
    and check your wiring and earth
    2 in the pink 1 in the stink
    Moderator Sam-Q's Avatar
    Endeavour Hills
    and the brake switch is next to the pedal itself
    Jan 2015
    Dylan
    Warragul
    How'd you fix it, Im having the same problem with my pano
    Marco
    North Adelaide Suburbs
    Not sure if the pano had the same green box in rhs rear panel of an ae86 mine had cold solder joints and caused brake light and reverse lights to stop working
    Noooob
    Check for power at the brake light switch.
  1. Electrical issues - Dash, parkers, tail lights not working in Ke70
    By Low Style in forum Technical - Questions
    Last Post: 18th April 2013, 05:51 PM
  2. AE86 Reverse lights not working ...its not the globes...
    By LEVIN86 in forum Technical - Questions
    Last Post: 30th December 2010, 10:25 AM
  3. ae71 reverse lights
    By Aezion in forum Technical - Questions
    Last Post: 20th February 2009, 07:09 PM
  4. Reverse lights
    By KonaKid in forum Technical - Questions
    Last Post: 5th April 2007, 04:15 PM
  5. Park lights not working (front and rear)
    By yoshimitsu9 in forum Technical - Questions
    Last Post: 8th December 2005, 08:57 PM
