Page 22 of 40 FirstFirst ... 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 ... LastLast
Results 211 to 220 of 400
Thread: Universal 3sge (inc Beams) into AE/KE thread
  1. #211
    Dec 2009
    Andrew
    California
    Nothern
    USA
    Sam, he was looking for pics of the other people's beams swap.
    Andrew
  2. #212
    Glenn
    North Ringwood
    ok if any 1 is going to use the beams engine mounts ,beware they tear very easily ,you are better to use 2 s engine mounts and brackets ,have had a few guys with std road cars up at track meets with broken weeping engine mounts
  3. #213
    Glenn ke_70's Avatar
    Clay
    Barossa!
    thats a pretty cool gearbox crossmember!
    you'll find my thread in my sig.
  4. #214
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    Just so I get the right set-up. With brackets you mean the ones that bolt onto the engine right? The mounts obviously bolt onto the brackets but what about the crossmember?
    Does this need a lot of modifications when using the 2s engine mounts?
    ADM AE86 Levin
  5. #215
    Glenn
    North Ringwood
    its the rubber engine mounts that are no good
  6. #216
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    Yeah I get that but I was wondering which part you meant by brackets, but I'm assuming those are the ones that bolt on to the engine.
    ADM AE86 Levin
  7. #217
    Jan 2011
    Aram
    Noord-Holland
    Haarlemmermeer
    Netherlands
    KE70, I'll check that out, thanks!
    CRA45, I am not going to track my car, maybe a driftday here and there, but it will be 99.9% street use, do you think they will survive that?
    If not which mount could I use that would not require any alteration to the subframes, because I'm kinda done with working on them hehehe.
  8. #218
    User fantapants's Avatar
    Pat
    sorry for late reply.
    brad is steroidchickens. Has more pics on his build. we didnt modify our starters at all, used a plate to space out a 22r starter motor the right distance. Worked perfectly. His car has now been bought by someone who hasnt mentioned it here i dont believe, pm if you want their details, he may be able to confirm details and get better information for you.
    06/07/2011
  9. #219
    Timmy D
    North
    Cough..* he he
    How heavy is a 3s over a 4age?
    The reason I ask is I'm considering what front spring rate to select.
    Do you need to run a heavier spring or can we just go off all the info with ae86 running a 4 a?
    JJ
  10. #220
    Clay
    Barossa!
    i don't think they're really that much heavier. somthing like 8kg?
  1. What did you do on your ae/ke today thread
    By dove grey 64 in forum Melbourne & Vic Events and Discussion
    Last Post: 19th December 2013, 01:49 PM
  2. 3SGE Beams
    By Jacobxxx in forum Ebay Items - My Stuff
    Last Post: 29th October 2012, 12:03 PM
  3. 3sge Beams Coilpack
    By HiroshiFumi in forum Cars or Parts Wanted
    Last Post: 14th January 2012, 06:33 PM
  4. Replies: 12
    Last Post: 29th November 2010, 09:00 AM
  5. beams 3SGE questions
    Last Post: 22nd May 2009, 07:50 PM
