<- pg 13
Google came up with them.
I was always told not to mount to rear seat belt anchor points and to mount to the harness bar on the cage which you probably don't have. Sorta contradictory info as one site says mount to rear seat belt point BUT keep it at 20 deg which I don't think an AE86 will do. and that info's from a Japan company anyway. You will fuck your back up if you crash with the harness set up incorrectly, so do it right. One CAMS guy told me not to mount to rear seat belts due to length and stretch; he said he'd seen the helmet hit the windscreen because the harness mounted to the back stretched so much. probably a high speed impact though.
