Results 1 to 8 of 8
Thread: few questions
    Senior Member fergie's Avatar
    Feb 2010
    kiall
    adelaide hills
    Default few questions
    alright ive got a few questions dont laugh if some sound a bit noobish
    1) do 4ac run alright with avgas cos i can get it real cheap
    2) when rolling guards do i need to take the black plastic inside out permanantly if so does this make it loud inside
    3) i heard from a bloke that theres a place in SA that sells real cheap motors but with engne numbers ground off and yes i know that its real dodgy pm me if you know
    4) is there a forum like this for utes cos i need bits for my triton
    5) would i be able to do a 20v conversion in a weekend or would i be better off 16v ive never done a conversion but ive taken about 3 motors out and put back in (only in aircraft which are fair simpler)
    thankyou
    Veteran stx-16's Avatar
    Tweed Heads
    1: i dont know
    2: yes take it out before you start rolling or flaring or the screws will mess up your work
    3: i dont know
    4: google it and there should be something
    5: if you have everything all together 100% ready to bolt in i guess you could but there will always be something that will go wrong so i would say no you cant do it in a weekend and yeah a 16v is easier
    you play halo?
    add me GT: samnbhnc
    Veteran 70rolla's Avatar
    May 2010
    Tyler
    Sutherland Shire
    20v will take a bit of work pending hwat car its going in
    Veteran shift_rook's Avatar
    SE Burbs
    1) it's a higher octane fuel so yeah it'll run sweet, wind some timing in and experience the immense power or possibly having an extra 2kwatw from avgas
    2) no i've never noticed any noise difference by taking the liners out, it's just to stop mud and dirt and shit flinging inside the guard and door jam
    3) that sounds like a bad idea, if you get pulled over by a cop and they inspect engine numbers expect to be bent over
    4)
    5) that's a pretty broad question, i'd guess at no cause shit always pops up you aren't expecting or forgot, make room for 1 week at the minimum
    Veteran biggo's Avatar
    Nick
    Noosa
    3 - if you take it over the pits, they will have to stamp a new number onto it. The number comes from the dept of transport, so you could be getting into more trouble than its worth.
    Feb 2010
    kiall
    adelaide hills
    yea i guess but the bloke i was talking to (he was quite intoxicated) said i could get a 3sgte and fitted for $2000 which sounds flippin awesome
    Jonathan
    fergie: Put avgas in your 4A-C, advance the ignition timing a bit. Drive it. Fix the oil leaks. Replace suspension bushes with Nolathene. Buy new shocks. Enter hill climb.
    Do a conversion in 2 years time.
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    ^^ +1
  1. Few questions.
    By Dish in forum Technical - Questions
    Last Post: 25th April 2008, 09:21 PM
  2. Few Questions
    By damo46 in forum Technical - Questions
    Last Post: 25th April 2008, 03:38 PM
  3. A few questions
    By Gullie in forum Technical - Questions
    Last Post: 15th April 2008, 02:13 AM
  4. Few Questions
    By donp in forum Technical - Questions
    Last Post: 11th October 2005, 10:35 AM
