hey guys need to make up a custom clutch line cause i keep burning the stock one, but i need to know what copper pipe to get, can someone tell me the size and diamater of the pipe i need and the tread pitch and size of the endsthanks guys
You need to go to your local Enzed, and get a flexible braided line made up. I think it is actualy a teflon hose, coated with the stainless braid.
Rather than have the standard rubber hose copyed, you want a banjo fitting on the slave end, with a banjo bolt (and soft metal washer on either side of the fitting). The threads on both ends is M10x1, which is the same on all Toyotas.
