Results 1 to 7 of 7
Thread: Hilux diff models
    Senior Member tezza88's Avatar
    Terry
    Lansvale
    Default Hilux diff models
    Cant seem to find out what model Hilux's will have a diff which has very similar track to the AE86 rear end. Found a few articles on how to adapt a Hilux diff but not so much on the actuall model of the Hilux used.
    Any help would be great.
    Senior Member ach_66's Avatar
    Azz
    Newcastle
    My 86 has a Hilux rear end. I didn't do the conversion though. I can tell you the diff centre is out of the rear axle of an LN106 (89 to 97) model LSD 4WD. I'm not sure about the housing though. Could measure it from face of bearing flange to flange if that helps
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    The OLD OLD hilux is the one your want... Can remember exactly what model though. Something like the 87 model rings a bell... A quick search should be able to answer the question.
    Search for the Dirty Ibis build... that will tell you..
    Calvin
    Kilsyth
    nah needs to be older than that. late 70's is same as corolla
    rn25/27 the rn40 early 80s is alot more common and only slghtly wider than corolla. 1410mm apparently.
    T18 in the build
    Jason
    Nundah
    Ahh thats its.. rn40.. keep think r140 for some reason... Rn40 is what I have in mine.. Think the REALLY old ones a 1390 or 1380..???
    Terry
    Lansvale
    Awesome thanks, an rn40 shouldnt be too hard to find loll Does the extra width in that rear end make huge handling issues?
    Jason
    Nundah
    HAHA.. the width would have almost no effect campared to the extra weight.. they're HEAVY fuckers..
  1. Replies: 0
    Last Post: 1st July 2012, 01:36 PM
  2. hilux diff
    By rolla92 in forum Technical - Questions
    Last Post: 22nd June 2009, 06:59 PM
  3. Hilux diff
    By joshz18 in forum Car Parts For Sale
    Last Post: 8th June 2009, 10:38 PM
  4. hilux diff
    By Fozz in forum Technical - Questions
    Last Post: 4th June 2009, 10:08 PM
  5. F-Series Tarago Diff Models and Years?
    By lloydious86 in forum Technical - Questions
    Last Post: 24th May 2009, 11:11 PM
