Results 1 to 10 of 13
Thread: re welding headers
    Yang
    Salisbury
    Default re welding headers
    hi just want to know if its a good idea to re weld headers? i notice a crack on mine where the welds join the pipes. i just want to know if its worth doing?
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Why wouldn't it be a good idea.
    You think driving around with it cracked is going to be better..??
    Just get it welded... Mush cheaper than replacing them..
    Yang
    Salisbury
    kool thanks mate! just a small hair line crack, i didnt want to do more damage to the extractors especially when they are stainless steel jap header
    Jason
    Nundah
    Ahh well you didn't mention that....
    Still get it welded but make sure its tig welded with the right wire..
    And try and work out why its cracked in the first place...
    has the exhaust been made a little wrong and is placing alot of weight on the headers..
    Are they old..??. stainless is pretty shit material for headers.. It can't handle the constant heat cycles and becomes brittle.. Hence why they always crack..
    Moderator Sam-Q's Avatar
    Endeavour Hills
    get someone to tig weld it up, I don't suggets you take it to an exhaust shop, I heard many of them don't even run stainless wire when they weld their stainless systems in their workshops with their mig welders
    Jason
    Nundah
    Of corse they don't.. why would they.. ???
    How often does a weld rust out before the exhaust pipe does.?? never..
    Even a stainless exhaust would need replacing from damage or stuffed mufflers befor the welds were rusted to the point of leaking..
    Endeavour Hills
    because it's structurally inferior and its more prone to crack. If you want to do it right you need to use pure argon and stainless wire
    Jason
    Nundah
    Yeah thats to do it RIGHT.. how many stainless exhausts do most shops do you think.??
    Hardly any... Its not worth there time to waiste changing wire and gas bottles. plus the extra expense of having an argon bottle sitting around that only gets used once in a blue moon..
    Plus how many ppl would know anyway..?? Bet 95% of ppl that get a stainless system don't even look under their car..
    And if it did fail (after ages) they'd just go back an exhaust shop and get them to fix it.. Not even realising it failed because of lazy work practise in the first place..
    Endeavour Hills
    ok I think I know what angle your looking at it from now, your talking from the point of view of the exhaust shop, not for this guy. Well anyway you have shown my point and for this guys extractors I think a fabricator with a tig welder is the way to go.
    Jason
    Nundah
    Definatly.
  1. what welding rods to use when welding a diff???
    By macca1590 in forum Technical - Questions
    Last Post: 14th March 2011, 10:36 PM
  2. Welding?
    By gumbie in forum Brisbane & QLD Events and Discussion
    Last Post: 18th June 2010, 07:42 PM
  3. Welding
    By Low Style in forum Technical - Questions
    Last Post: 28th October 2009, 08:05 PM
  4. welding....
    By Ade_Mc in forum Technical - Questions
    Last Post: 11th August 2007, 03:16 AM
  5. Welding help?
    By Bustin_86 in forum Technical - Questions
    Last Post: 26th August 2006, 03:30 PM
