With the factory Toyota LSD centre (TE71 and AE86) the axles were a little shorter due to that LSD design. However if you use a TRD or KAZZ or any other brand LSD, the axle length will not matter. The LSD axles will not be too short.
I have recently replaced the axles in my zenki diff as the spline was wearing out and slipping (horrible noise)
Now, with a standard LSD t-series, the axles are 7mm shorter than open center t-series.
My question is now if i want to purchase a new; say Kazz 2-way will the axles be to short or are the aftermarket LSD's designed with the shorter axles....
That is awsome.........
Thanks Jonny
