Results 1 to 5 of 5
Thread: ****Disk brake E series diff, braided lines, 4 traction brackets, locked centre,etc*
    Senior Member kaibeecee's Avatar
    Pete
    Default E-series diff to bolt into AE86/71! traction brackets, speedflow breather, braided!
    For sale: Disk brake E series custom diff
    Price: $1000
    Contact: Brett Mattingley- 0433 191 205 please call rather than PMing as im not on the net much
    Diff- 4.3 E series, 4” extended lower mounts, enlarged breather with Speed flow fittings, new bearings, extra long 75mm studs, s13 disks with ENDLESS brake pads, braided lines to the diff and to the callipers, T3 rubber (reusable) diff gasket, diff centre built by TOP COG with a locked centre, diff housing painted in gray urethane 2pack. I have run this rear end for the past year without a problem, the diff has quality oil in it and is ready to go (does not have spring perches, I can add these or convert ur shocks to coilovers)
    $1000 will freight at buyers expense, if buyer organizes
    Pete
    this is still here!!
    too cheap for what it is but i need it gone!
    Senior Member 4agte70's Avatar
    Feb 2010
    Wayne
    Happy Valley
    Shit the breathers a bit of overkill dont ya think? Decently priced tho
    20V silvertop, HKS 2510, Microtech LT10s with dash display, A Spec coilovers, AJPS RCAs + traction brackets, T3 adj trailing arms, TRD 2 way, braided brake lines,Kelway half cage, Cusco cambertops and braces. 174rwkw @ 15psi....SOLD
    CA18det Gayzelle cooner
    paul123
    Interested in this. Will call tomorrow to discuss (probably wouldnt appricate call at 11PM
    Pete
    breather is normal size for a diff. they use -12 fittings alot on diff cooler setups in race cars. just put a line with a filter on it and you're set.
    no worries paul! best to call after 3pm, tho brett will return your call ASAP if missed...
  1. Replies: 2
    Last Post: 30th September 2011, 04:35 PM
  2. [BNE] CIG locked S-series diff centre - go drifting!
    By kaibeecee in forum Car Parts For Sale
    Last Post: 21st August 2010, 11:35 AM
  3. WTB: T series diff centre, locked or open 4.1 or 4.3 VIC
    By Sprinter86 in forum Cars or Parts Wanted
    Last Post: 20th July 2010, 06:43 PM
  4. WTB: LOCKED S-Series diff centre
    By .ady in forum Cars or Parts Wanted
    Last Post: 25th July 2009, 10:40 PM
  5. wtb t series diff centre, locked or not
    By marioman in forum Cars or Parts Wanted
    Last Post: 10th July 2009, 02:38 AM
