Results 1 to 10 of 14
Thread: Built 16v 4AGE motor and gearbox package
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    Default Built 16v 4AGE motor and gearbox package
    Just an EOI at this stage, motor will properly be for sale after july 25th.
    Motor:
    4age 16v bigport
    Balanced bottom end
    Decked block
    Shaved Head
    Ports/combustion chambers tidied up
    Heavy duty valve springs
    264 cams, 8.4mm lift (from memory)
    Vernier pullies
    Baffled sump
    T3 Quad throttle adaptor
    silvertop throttle bodies
    Custom made Trumpets
    2ZZ Coil on plug ignition
    GZE CAS
    FGK Exhaust manifold and full under diff exhaust
    440cc injectors
    bigport fuel rail
    all new water pumps, oil pumps, rings/bearings etc when it was built.
    engine mounts
    Drivetrain
    Toda flywheel
    Xtreme Paddle Clutch/ Heavy duty pressure plate
    Rebuilt JDM T-50 with lockwired selector fork roll pins (eastern creek proof :lol: )
    C's Short Shifter
    Reduction Starter motor
    Motor has done approx 1500kms since being built, Gearbox maybe 2000kms.
    Makes 105kw at the wheels running on E85.
    Has been a very reliable package, only had some issues with oil pumping out the cam covers at eastern creek, all it needs is a dual breather hose setup on the cam covers and it would be fine.
    Looking For $3500 for the whole lot, not willing to seperate unless people want to sort out parts amongst themselves.
    This motor has cost me approx $5000 to build, nothing wrong with it, im just going to a beams for more power. Ready to bolt into an 86/KE etc just needs and ECU and away you go.
    Can organise freight for interstate buyers
    Andy
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    what pistons does it have and do you have a dyno printout?
    the dyno pull to 300rwkw
    Andy
    Adelaide Hills
    Standard pistons,
    have a sheet somewhere
    Andy
    Andy
    Adelaide Hills
    bumpoooo
    Andy
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    So nice and clean.
    For reference could i get a close up of the end of the clutch master and the 4th trumpet? Curious to see if the clearance has changed between the first and second revision of the T3 manifold.
    For everyone else, this setup is well worth it. Pretty well bulletproof in the bottom end, and would breath nicely at the top.
    Ridgehaven
    Fairly tempting Andy
    Out of interest what ECU did you run, and why is it not included?
    Andy
    Adelaide Hills
    Haltech e8, which I will be using on the beams
    Andy
    Andy
    Adelaide Hills
    back to the top
    Andy
    Senior Member billett86's Avatar
    Mar 2010
    Toby
    Adelaide Hills
    still for sale?
    Andy
    Adelaide Hills
    yes still here
    Andy
  1. 4age 16v rwd engine package
    By pen15 in forum Car Parts For Sale
    Last Post: 13th May 2013, 10:50 PM
  2. 7AGE Engine Package. Motor + Gearbox + ECU. HAWWWWT STUFF
    By Robo86 in forum Car Parts For Sale
    Last Post: 11th November 2011, 02:43 PM
  3. 4age 16v Bigport Engine Package
    By DR71FT in forum Car Parts For Sale
    Last Post: 27th April 2011, 04:21 PM
  4. [SA] WTB: Built 4AGE 16V/20V or GZE
    By s3phro in forum Cars or Parts Wanted
    Last Post: 12th March 2011, 08:29 PM
  5. Replies: 13
    Last Post: 11th November 2010, 05:22 PM
