yeah true. might not go that big then. what would be a close fit to just rolled non flaired gaurd on a ke7?
If that's the case you're definitely going to need some guard work. The more you push the track out on the front (with LCA's) the more guard work will be required.
well I'd just go 14x7 +/-0 with some xt130 arms and some low.
Why do you want soo mutch camber? Is it just for style? I wouldn't be playing around with handling untill you can drive properly. Increasing the camber makes the car a bit sketchy on bumpy roads and you will be fighting with the car to stay in a straight line.
I must admit wide rims and some mass camber does set the car off but don't be one of those P platers on the TV that crash through fences trying to be fully hektic, we have enough communist propaganda against us as it is.
Dont run big camber just to make your wheels fit.
Don't run sigma's they mess with your steering geometery and put the front and rear track out of even, not to mention they make it even harder to fit wide wheels as they increase track by a large amount.
Why do you have to run spacers? You do not want to, they are not the right way to gain track.
Anymore than -3 camber is too much for street tyres and will reduce your straight line braking ability as you lose surface contact area of you front tyres.
If you want a flush stock rolled guard fit with 13's, you are looking at 13x8J 0 to -5, 7.5J -5, 7 +-0 with 185/60/13's
haha yeah i understand with that. just to fit some wider wheels on i will need alil camber. i dont want them massive bolted on gaurds.
and ive been doing hill climb shit since i was 14. so i have a fair idea on how a car handles. not trying to sound like a know it all wank.
and this ke will only be for track use. hopefully full cage and all stripped so yeah no rego for mee! i have a daily subaru impreza
Awesome, just I have an extended family member that has only just got his licence and staked the car 4 times already. Fences, poles, letterboxes and parked cars.
I can't wait to do some hill climbs, Currently rebuilding my track car and attempting to build a 7age 20 valve.
This.
-3 camber with lots of castor is a winner.
You should be able to fit bigger then 13x8J 0 to -5
okay ill try that. cheers fellas.
