Results 1 to 7 of 7
Thread: 20V Silver Top trumpets and other bits
    Senior Member lawrencelalot's Avatar
    Feb 2010
    Jack
    Glynde
    Default 20V Silver Top trumpets and other bits
    Howdy.
    I need some parts for the conversion.
    -Silvertop trumpets/ram tubes/velocity stacks
    -Silvertop ECU and loom
    -TPS
    Probably some other stuff too...
    PM me if you have anything.
    My story begins in nineteen-dickety-two. We had to say dickety because the Kaiser had stolen our word twenty. I chased that rascal to get it back, but gave up after dickety-six miles.
    Jeff
    Northern Beaches
    I have itb's with tps If interested...
    Will
    i may be able to help you with alloy trumpet flanges if you are keen on a bit of DIY, just need to get some spun trumpets from JNT or whatever and weld them together.
    Feb 2010
    Jack
    Glynde
    I have the ITB's, I only need the TPS.
    I don't have the facilities. I'd just rather buy them
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Silver top ecu won't work with trumpets unless you have airflow meter prior an airbox (surgetank), as standard it runs an airflow meter not Manifold Absolute Pressure sensor
    Blacktop std ecu you can run trumpets. (MAP sensored)
    Feb 2010
    Jack
    Glynde
    Alright. So you tell me what I need. Can I use a blacktop ecu without too much screwing around?
    Marco
    Yes you can use blacktop ecu, however you will need an air intake temp sensor, and map sensor (AE92 4age small port).
    Blacktop ecu. silvertop loom, and another ecu plug from a Camry? I think i got mine from.
    Pinouts are available on Club4ag, and use silvertop wiring diagrams.
    I converted my AFM silvertop to MAP and blacktop ecu.
  1. WTB - trumpets / velocity stacks 20v silver top
    By alexthekid in forum Cars or Parts Wanted
    Last Post: 14th August 2012, 11:31 PM
  2. ae71 t-shaft, t50 clutch fork+shifter, silver top trumpets [bris]
    By hakasherpasherpa in forum Cars or Parts Wanted
    Last Post: 24th July 2010, 06:09 PM
  3. Replies: 5
    Last Post: 12th May 2010, 03:36 PM
  4. are bt 20v and silver top 20v cam covers the same??
    By slider4life in forum Technical - Questions
    Last Post: 1st April 2010, 06:08 PM
  5. 20v silver top trumpets
    By ROSCO in forum Technical - Questions
    Last Post: 3rd July 2007, 08:12 PM
