does it crank but not fire?
Car - ke70
motor - 4ac
use - daily
problem -
occurs/started when - I tried to turn it on last night
personal situation - need daily back from the dead
so the 4ac wouldn't start last night after going for a run, had the RAA diagnose the problem as a blown head gasket. pulled it apart today and found it was. so I changed it. now its all back together and still wont start. what else could the problem be?
yeah pretty much
definitely getting fuel and from what I can tell there is spark.
I think I better check the timing tomorrow
If theres 1 thing i remember about pulling t50's out of ae86 with 4ac's
DONT TOUCH THE DIZZY.
Ill bet its the dizzy thats wrong. Or the cam isnt in time.
Perhaps swap a few leads around and see if it changes anything. Flames out the carby anyone. If it does then its the dizzy fo shizzle
maybe taking the gearbox out of the car with the engine as one?
but yeah atm my money is on the timing/dizzy
points in the dizzy may be worn
