Results 1 to 5 of 5
Thread: re-wiring alternator from 4ac to 4age
    Eastside
    Default re-wiring alternator from 4ac to 4age
    Car - ae71
    motor - 4age 16v
    use - dori
    problem - alternator wiring
    occurs/started when - new motor and wolf 3d
    personal situation - getting extremley pissed off
    hey guys,
    having some problems with wiring up my car to the wolf 3d.
    1st off, i've trowled the net looking at diagrams etc for hooking up the wiring for the 4age alternator.
    now i know the 4age has a internal regulator so i no longer need mine.
    now read some post etc and found the correct wires to hook up to my alternator, but they all come from the regulator loom. is this correct?
    Some postman, is groving... to all our love letters... some postman is gonna cry! - Some postman you turned out to be..
    Veteran Skylar's Avatar
    Ken
    I don't really know what you're saying but alternator has a 3 pin plug and a big fat wire. The three pin plug has a white wire and two others. You can join the white to the big wire. The other two wires, run them to the plug the where the regulator used to plug in and match up the colours.
    Alternator wiring on the 4age...
    IGN - 12v ignition power
    S - 12v Constant Power
    L - Earths out the light on the dash.
    Thick White Wire - 12v Constant power
    L - Is the yellow wire
    S - Is the white wire
    IGN - The other wire colour
    I'd recommend not joining the smaller white to the bigger white wire, and connecting it via a fuse to the battery. I've seen weird things happen when people do this with voltage regulation.
    Dave
    you cant have trawled very hard....
    FAQ of rollaclub has stacks of info
    here you go:
    - Blaise Pascal
    Mt Macedon
    Find the AE86 manual with the long pullout wiring diagrams in the back (it's around the net a few places). It includes both int. and ext. reg alternators.
    If you draw a box around the 4AC alternator and reg there are 3 wires coming out. Draw a box around the 4AGE internally regged alternator and there are also 3 wires coming out, which happen to be the same colours. Connecting them should now be obvious.
  1. wtb 4ac ae71 alternator wiring
    By rthy in forum Cars or Parts Wanted
    Last Post: 22nd January 2010, 06:57 PM
  2. 4AGE alternator wiring in a KE70
    By Gilly in forum Technical - Articles
    Last Post: 27th March 2007, 09:49 AM
  3. KE70 + 4AGE + alternator wiring
    By dr1ft-pig in forum Technical - Questions
    Last Post: 26th March 2007, 04:08 PM
  4. 4ac alternator wiring
    By damo_00 in forum Technical - Questions
    Last Post: 24th November 2006, 08:53 PM
