Hey guys I'm after the torque settings for the T50 clutch. Installing the new one today, just need to know the correct torque from the FSM.
Cheers,
Cheers,
Straight from the manual:
Tighten the bolts evenly and gradually. Make Several passes around the cover until it is snug. Torque the bolts. Torque: 195 kg/cm (14ft-lb)
^^ Quite a few torque-wrenches won't go this low, so you might have to just guess it. 14ft-lb is really bugger all, and i know from experience that those clutch-cover bolts are easy to snap![]()
Cheers! Mine does w00t!
