Results 1 to 8 of 8
Thread: Ke70 steel thickness
    Senior Member odessy's Avatar
    Blake
    Qld
    Bris
    Default Ke70 steel thickness
    Finally getting a welder in the next few days. Does anyone know the thickness of steel on the body of a ke or what thickness I should use for replacing rusted spots. Its on the rear quarters and boot seal.
    Mar 2010
    i think 0.8mm thick steel (it could be 0.6mm and you replace with 0.8mm not 100% sure)
    Gone
    Joel
    Picton
    Panels are only thin, can cut no worries with Tin snips, Less then 1mm
    Blake
    Qld
    Bris
    I've was given some 1mm thick zinc coated steel off cuts. Should these be fine to use?
    Ok
    Seamus
    Milton
    Yep it'll be sweet.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    yeah I agree, some of the best stuff is pieces from an old washing machine
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    id be getting old panels and choppign sections out, using thicker steel in patches distorts the shit out of body panels, also use .6mm in ur welder!!!!
    AE86 THE BEST
    Brandon
    Blackwater
    alot of people a spare bonnett up for rust repair works a treat
  1. Brake Disc Thickness
    Last Post: 26th September 2012, 01:41 AM
  2. RCA thickness?
    By ke70dave in forum Technical - Questions
    Last Post: 4th March 2010, 11:25 PM
  3. stock steel rims for ke70
    By rhys2229 in forum Cars or Parts Wanted
    Last Post: 14th December 2009, 07:24 PM
  4. Oil thickness and grades
    By PHAT86 in forum General Topics (No Technical Questions)
    Last Post: 11th January 2006, 02:08 PM
