Results 1 to 4 of 4
Thread: injectors question
    Billy
    vic
    Templestowe lower
    Default injectors question
    hi guys:
    just a quick question!
    i just wanna know if a JDM big port 4age ECU running with high impedance injectors will occur any damage at all?
    apprently i have got a set of cams 272' and 264', what size of injectors should be good to run with? coz i am not too sure what sort of power will pull out from these cams
    thanks
    Jonathan
    If you don't have a programable ECU, you always need to run the exact same injectors the ECU was originaly matched too (or of the same flow rate at least).
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    jonny is correct, and i was maxxing out standard injectors with those size cams
    Andy
    Billy
    vic
    Templestowe lower
    Thanks for the reply
    I do understand to run the standard injectors with the standard ecu is better
    but what it was...I blew up my jdm big port motor and get myself a small port 100kw motor instead.
    The ecu I am using now is jdm ecu plus emanage blue with full optional wiring.
    And for the injectors I have a set of 7mge, standard 100kw injectors and also a set of evo9 injectors. 2 set of toyota one are high impedance only the evo one is low impendance, but it will be way to big for a na car.
    So Should I try the 100kw injectors or the 7m one?????
  1. Replies: 0
    Last Post: 2nd May 2010, 04:13 PM
  2. Quick clutch question and spigot question
    By wideslider in forum Technical - Questions
    Last Post: 9th August 2008, 12:45 AM
  3. 7mgte injectors, bigport and smallport injectors
    By Rich_86 in forum Car Parts For Sale
    Last Post: 13th March 2008, 09:22 PM
  4. SARD Injectors 534cc Part number 63501 (4 Injectors)
    By gasit in forum Car Parts For Sale
    Last Post: 13th December 2007, 10:41 PM
