Results 1 to 10 of 10
Thread: i want to fit 20v itbs on 3-sge
    Shaun
    Capalaba
    Default i want to fit 20v itbs on 3-sge
    hi guys considering this as the cut and shut job on the intake has cracked again,
    the engine is gen2(i think) from mr2 fitted to ae86 running microtech
    is there a manifold available to fit the 20v itbs ?
    is it a worthwhile upgrade?
    if anyone has done it before or has some info on doing it, that would be great
    thanks shaun
    Senior Member plohl's Avatar
    Mar 2010
    Shane
    Carseldine
    i know you get ITB kits for 2nd gen 3sge's, though - they are not cheap. Unsure if the 20v ones would fit.
    Have a look at - they used that have stuff for the 3sge (doesnt look like it now) but i have got some stuff off them a few times and they are pretty helpful, so might be able to help you out.
    Also, do you know what the microtech is using for the fuel map? like air temp and manifold air pressure? or is still using an airflow sensor?
    Cheers, plohl
    User fantapants's Avatar
    Pat
    check biggos thread, im sure he had one made for beer....
    06/07/2011
    Moderator Sam-Q's Avatar
    Endeavour Hills
    yeah biggo did it using what appeared to be just exhuast pipe sections.
    Aaron
    you can get adapter plates to suit 20v quad throttles. i know at kyp they have a beams 3s with 20v quads on it
    Aaron
    In the Mountains
    surgest bracing or find a new welder for current manifold.
    if you already have a ECU then ITBs wouldnt be that expensive to swap.
    id say a worth while upgrade and a nice bump in power when combined with some cams.
    Endeavour Hills
    I guess we better ask what version of 3S you have, also show a pic of your manifold maybe we can sugest what needs changing
    Pat
    its a gen 2 sam, same as biggos i think...
    06/07/2011
    Veteran biggo's Avatar
    Nick
    Noosa
    neg, his is different. But im 99% sure its the early model flange bolt spacing, so maybe thing of trying to score an early gen2 tvis mani, they have the throttle body in the middle so no cutting and shutting.
    Shaun
    Capalaba
    thanks for the replies
    its gen 2 from mr2
    computer is microtech ltx-8
  1. WTB: 20v itbs
    By sld sho in forum Cars or Parts Wanted
    Last Post: 4th June 2011, 10:55 PM
  2. ae71 tail shaft, TPS for 20v ITBs
    By hakasherpasherpa in forum Cars or Parts Wanted
    Last Post: 13th September 2010, 07:32 PM
  3. what standard rad will fit in my ae86 with a 20v 4age
    By slider4life in forum Technical - Questions
    Last Post: 31st August 2010, 02:23 PM
  4. 16V headers fit 20v?
    By DAMO46 in forum Technical - Questions
    Last Post: 12th November 2009, 12:46 PM
  5. Will 20v extractors fit 16v??
    By haydenzz in forum Technical - Questions
    Last Post: 8th December 2007, 03:11 AM
