Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: another clutch question
  1. #11
    Member D4NI3L's Avatar
    Jun 2009
    Daniel
    Croydon
    firstly bleed, if it's still doing it it's problerly worth checking the clutch fork, i've had the problem before and the clutch fork turned out being cracked, couldn't really see it because it was really dirty.
    Life is best spent \\Sideways//
  2. #12
    Senior Member pieman18's Avatar
    Dan
    Caulfield South
    as of tonight she is back on the road and driving beautifully
    bled the clutch and it got firmer straight after i poured new fluid in, and squish_m8 u were right, bleeding the clutch is easy as
    time to give her a well deserved service i think
    thanks for all your help guys
    Formerly: sprinters_r_mad
  3. #13
    Senior Member DearmanKE's Avatar
    Alex
    Northfield
    if there was fluid inside the slave cyl boot then the piston seal is leaking,
    it will work just keep an eye on your fluid level
    Formerly known as grape_moosha
  1. 212mm clutch question
    By trikzlane in forum Technical - Questions
    Last Post: 1st August 2011, 02:20 AM
  2. Quick clutch question and spigot question
    By wideslider in forum Technical - Questions
    Last Post: 9th August 2008, 12:45 AM
  3. clutch question
    By muldog86 in forum Technical - Questions
    Last Post: 3rd January 2008, 10:03 PM
  4. Clutch question
    By unit101 in forum Technical - Questions
    Last Post: 24th May 2007, 03:14 PM
  5. clutch question
    By meadan in forum Technical - Questions
    Last Post: 28th March 2007, 10:47 PM
