Results 1 to 8 of 8
Thread: sr20 ecu
    Veteran stx-16's Avatar
    Tweed Heads
    Default sr20 ecu
    so im all most finished putting the na s14 sr20 in to my ke70 i just need to find the rite ecu
    motor specs:
    sr20det injectors
    thinner head gasket (not sure how thin the previous owner did it)
    and one day it will have itb's
    im thinking of getting a power fc with hand controller does anyone know what would be ok?
    you play halo?
    add me GT: samnbhnc
    Ok
    Seamus
    Milton
    the problem with a normal power-fc is they still use standard sensors i.e. AFM
    this means if you go ITBS, you HAVE to make a sealed plenum with an AFM after it etc .. kinda ruins the coolness of going ITBS
    your best bet would be to go something like an adaptronic, which comes with its' own MAP sensor, so you can remove the crappy AFM
    Tweed Heads
    thanks but i am 100% not using an adaptronic iv heard to many horror stories and yeah cbf lol
    anything else?
    you play halo?
    add me GT: samnbhnc
    Ok
    Seamus
    Milton
    power-fc djetro
    haltech
    microleb
    motec
    link
    Veteran bigm's Avatar
    Gold Coast
    as above,
    there are horror stories from all ECUs, Power FCs, Adaptronics.
    If i were to go aftermarket it would be Haltech. but also depends on who can tune in your area?
    Senior Member plohl's Avatar
    Mar 2010
    Shane
    Carseldine
    Wouldnt you tune an na off throttle position?
    Cheers, plohl
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    smasha microtech on i run em on all my cars
    AE86 THE BEST
    Ok
    Seamus
    Milton
    normal power-FC's still require an AFM and other standard sensors
  1. VIC: ae86 and s14 parts plug and play sr20 ecu bride dmax
    By BMXB in forum Car Parts For Sale
    Last Post: 31st March 2013, 10:50 AM
  2. Replies: 4
    Last Post: 31st January 2012, 02:14 PM
  3. Replies: 0
    Last Post: 13th August 2010, 12:32 AM
  4. SR20 redtop ECU WIRING
    Last Post: 28th March 2010, 12:35 AM
  5. Autronic SMC ecu to sit SR20..
    By --Redwork-- in forum Car Parts For Sale
    Last Post: 11th August 2009, 05:28 PM
