Results 1 to 9 of 9
Thread: t50 gear box bolts
    Jul 2010
    Default t50 gear box bolts
    Car - ke70
    motor - 4age w/ adm t50
    problem - lack of gear box bolts
    personal situation - need to know specs so i can order gearbox and starter motor bolts.
    if youve got some lying around ill buy them or if youve got some handy some measurements would be tops.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Without going outside I can tell you they are an M12 with a 1.25mm pitch, I think the starter is an M10
    Senior Member Eddy's Avatar
    Edward
    go to toyota ask for parts specs, order bolts. i got all of mine for my sr for 37 bucks
    Quote Originally Posted by Nicko View Post
    Why don't you go drive a mates car around until you find a big tree?
    Veteran stahlz_ae86's Avatar
    Paul
    If you have a wrecker near you I'd be inclined to check if they've got an auto 71 as you should be able to use the majority of those bolts. I'm just in the process of converting my 71 from auto to manual and most of the bolts look like they'll be ok to use. I'll give you all the measurements later in the week (when I work on the car next) if you're still stuck then.
    Veteran haveaparty's Avatar
    Mar 2010
    Brett
    Crestmead
    ae 82 gearbox bolts is wat i got, go to ur local wreckers
    Anthony
    should have asked, could have thrown some in with your order.
    Rob
    Moorabbin
    just go to a wrecker an pull a whole bunch of bolts out of some 80's toyotas and find the right length.
    Measure your bellhousing flange and figure out the lengths that you need for each bolt. (shank length should be shorter than the flange thickness )
    Senior Member DearmanKE's Avatar
    Alex
    Northfield
    i used 4k bolts on mine, just goto wreckers
    Formerly known as grape_moosha
    Brandon
    Blackwater
    if u want to no the exact measurements they have them in the 4age manual im pretty sure, or just google it?
  1. T50 Gear box
    By timpy in forum Cars or Parts Wanted
    Last Post: 26th March 2012, 09:16 PM
  2. wtb T50 GEAR BOX
    By sunbeam in forum Cars or Parts Wanted
    Last Post: 19th July 2010, 07:59 PM
  3. Need a T50 gear box
    By Course_Out in forum Cars or Parts Wanted
    Last Post: 17th June 2008, 11:54 PM
  4. japspec t50 gear box
    By ozsprintz in forum Car Parts For Sale
    Last Post: 23rd April 2007, 08:52 PM
  5. WTB T50 gear box
    By fat86s in forum Cars or Parts Wanted
    Last Post: 17th April 2007, 11:28 PM
