Results 1 to 2 of 2
Thread: wheel bearings
    Senior Member fergie's Avatar
    Feb 2010
    kiall
    adelaide hills
    Default wheel bearings
    gday just had a quick question about wheel bearings ive never done em on cars are they tapered or not and whats the procedure for tightening them do you want much drag i dont imagine you wouldon cars but we tighten them till they wont quite do one full turn and then loosen to nearest hole
    thanks blokes
    Member adrian_809's Avatar
    Mar 2010
    Adrian
    I did mine just recently. Yes they are a taper bearing. Basically what I did was. After I packed them with grease and put them back in the hub. Was to put the hub on and tighten the nut up as much as I could by hand using a 1/2-inch ratchet. To seat the bearings then you back it off. And spin the wheel then gently tighten it back up little by little until the wheel free spins and slowly comes to a halt. You don’t want it to spin forever tho or for it to slow up to quickly. i can see its a little late but thought you might like to know how to do it any way
    The most important thing is balance. What is power without control?
  1. my wheel bearings hate me!
    By shaunpierre in forum Technical - Questions
    Last Post: 4th October 2011, 07:08 PM
  2. wheel bearings kouki vs zenki
    By ae86=fun in forum Technical - Questions
    Last Post: 16th August 2008, 03:20 AM
  3. Wheel bearings
    By daz in forum Technical - Questions
    Last Post: 17th April 2008, 10:57 PM
  4. Changing wheel bearings ?
    By jase ek in forum Technical - Questions
    Last Post: 7th August 2007, 11:34 PM
  5. Wheel Bearings and stuff
    By MINIHORSE in forum General Topics (No Technical Questions)
    Last Post: 28th May 2005, 04:18 PM
