Results 1 to 8 of 8
Thread: 20v Timing Belt whine started 3000k after i changed it WTF?!
    Senior Member dtour's Avatar
    Jun 2009
    Jon
    Ryde
    Default 20v Timing Belt whine started 3000k after i changed it WTF?!
    Car - AE86
    motor - 20v Silvertop
    use - its says personal on the rego?
    problem - Timing belt whine
    occurs/started when - 3000km after i changed it
    personal situation - boored, broke and confused
    So i replaced my timing belt before i installed my new motor in March, over the past couple of days the timing belt has started to whine. Its a genuine toyota belt too and I dont think timing belts magically tighten themselves.
    Has anyone seen or heard of this happening before?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    the tension isn't too much?
    sorry it's all I can suggest
    Veteran biggo's Avatar
    Nick
    Noosa
    pull the covers off tho and check its not rubbing on them.
    Jun 2009
    Jon
    Ryde
    i am pretty sure that the tension has increased, i took the cover off this afternoon and the belt isnt rubbing on anything so i am going to take the lower cover off 2moro arvo and check the areas i couldnt see
    im so confused :|
    Dave
    id would just reset the tension and see how it goes.
    cars do funny things sometimes.
    - Blaise Pascal
    Jonathan
    Maybe you need a belt tensioner bearing now also. It is common for a mechanic to replace the timing belt pulley/bearing/tensioner when a new timing belt is put on. Mostly just to save time down the track, as its harder to get to on a FWD.
    Make sure you have a silvertop belt and not one for a blacktop.
    When I put my Toda gears on, there was a bit of black T-belt dust for a while untill the belt settled into the new gears (which obviously are cut very slightly different to the stock ones.)
    Jun 2009
    Jon
    Ryde
    Hey jonny, yeah i replaced the tensioner at the same time.
    I did fix the issue however.
    The belt was just a little tight. F*^ked if i know how that happens but watever its fixed now.
    Senior Member DearmanKE's Avatar
    Alex
    Northfield
    its weird but ive seen it happen before aswell at work, had a couple 323's come back after a couple thousand k's and the timing belt is whining off its head. just retension and its all sweet.
    only happened twice that ive seen before but does happen
    Formerly known as grape_moosha
  1. 7ag 20V - which timing belt?
    By Grant #2 in forum Technical - Questions
    Last Post: 14th October 2012, 02:18 AM
  2. timing belt and tensioners in bt 20v???
    By slider4life in forum Technical - Questions
    Last Post: 8th April 2010, 07:26 AM
  3. Performance timing belt for 20v silvertop
    By DRFT - 86 in forum Technical - Questions
    Last Post: 22nd June 2008, 12:13 AM
  4. 20V Timing belt Teeth #?
    By 70XIN in forum Technical - Questions
    Last Post: 10th May 2008, 01:01 PM
  5. 20v timing belt
    By DRFTAE86 in forum Technical - Questions
    Last Post: 15th March 2006, 03:25 AM
Tags for this Thread
