toe is the main contributor to tyre wear, not just camber itself.
get 0 toe, -2 camber and 4ish pos caster thats what im running with a similar setup to yours and the car is very responsive.
Going in to get new tyres/alignment tomorrow......any suggestions.
Its going to be used for street and twistes every now and then.
Running
Coilovers
xt130 LCA's
Ps Arms
Lockspacer
Any help would be appreciated.
I've had a look at the grip alignments....it seems like everyone is running neg 2 and greater.....I want my fronts to last a little bit.
Thanks
yer avoid toe in.
id even say -1.5deg camber
im going for a wheel alignment today and im just gonna say 0 tie, -1.5deg camber.
and i set the castor my self untill it felt good, so am just gonna tell them to make them the same. ill be interested to see what value it is, i think its a fair bit though.
- Blaise Pascal
a bit of toe in is fine not more than 3 deg though.front wheel drive youd set to 0 rwd a bit of toe in.
^ toe is measured in mm, dono about running toe in though, never tried it.
i have tried toe out and the response is sick but at the cost of tyre wear. im sticking to 0 total toe
yea just went
-2.25 camber
+4 castor
+-0 toe
seems good, just have to mount the bumper a tad forward
max castor arms out -2.5 camber and toe.. really up to your profession
When you change caster it will put your toe out (in) so get the caster right first then get a wheel alignment or your wasting moneys![]()
sorry yeah mm,and he is right about the castor,especially if you are gunna max it out,
