They are out there you just have to be quick or they go in a flash, that is if they are any good.
The 2nd one (brown) was up for sale on firesport and i think carsales.
I got an ecu out of one of the group a cars, if you are building to that spec then would it be any use to you?
PM sent
Unless someone got the numbers wrong on my tape measure, they measure 8.5 inches inside the lip to inside the lip.
4 inch back spacing
4 1/2 front spacing
its not where the lip is, its where the face bolts to the hub..
and for width its bead to bead.
Woops didn't mean to start a poo discussion in your thread man, but yeh your measurements are of the wrong things :-) they are hot wheels nonetheless!
This is as per my measurements and they measure 8 1/2 inch, this is the way all wheel companies measure wheels, having been the state manager for a leading wheel company I am fairly sure I know how to measure rims
Good for you man
and BTW is RimZ
Any how back to the build, Coil overs arrived last week, car it getting RWC today, Disc rear with 4.77 ready to go in, Finished building the bottom end of the engine with 11.2:1 compression on the weekend so now need to pull down the good engine and transfer it all onto the built bottom end, Braided Brake lines should be here today, Adjustable Panhard rod will be here tomorrow, Seat are ready to go in, all coming together really.
