Look for a black with orange wire, it should be powered and power up the injectors from 12v ignition.
The ecu earths out the injectors as required, so make sure when u test the power you use a good earth.
Factory plug is a 3 prong in the shape of a T and from memory green in colour
Also check the main earth (brown that bolts to the side of the block) is connected tight
