Results 1 to 2 of 2
Thread: SYD brake nuts needed 10M 1.25 14mm nut not 17mm
    Leigh
    Penshurst
    Default SYD brake nuts needed 10M 1.25 14mm nut not 17mm
    HelloI was wondering if anyone would know where to get or would have some nuts for the studs that hold the rear drum assembly onto the diff
    when I took my diff apart the bolts were buggered so i had to cut the backs off and i have now found some replacement bolts but the nut are in really bad condition
    I've tried a fastener place and they only had 17mm nut for the 10M 1.25 thread and i need 14mm so I can get the socket through the holes in the axle to do them up.
    any one with ideas or the nuts them selves is a Champion let me know
    Leigh
    Leigh
    Penshurst
    found some on ebay all good
  1. [FS] BLOX Extended Lug Nuts (20x 1.25) -NSW
    By PKPAT in forum Car Parts For Sale
    Last Post: 26th December 2011, 02:33 PM
  2. Help needed with T3 big brake kit!
    By brutus in forum Technical - Questions
    Last Post: 26th September 2011, 05:13 PM
  3. Replies: 12
    Last Post: 16th June 2011, 12:02 PM
  4. Shock insert lock nuts and brake caliper bolts
    By Insane in forum Cars or Parts Wanted
    Last Post: 9th June 2008, 07:29 PM
  5. KYB Gland nuts (the nuts that screw your strut inserts in)
    By Patric in forum Cars or Parts Wanted
    Last Post: 3rd April 2007, 11:32 AM
