Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 36
Thread: car still too cold cant figure it out????
  1. #21
    Moderator Sam-Q's Avatar
    Endeavour Hills
    dual stage:
    single stage:
    just order an ae71 thermostat and make sure it has the flap on the bottom
  2. #22
    Jul 2009
    shaun
    nsw
    port macquarie
    Yeap that's what I have in mine a dual stage. Mine 100% has the flap.
  3. #23
    Jul 2009
    shaun
    nsw
    port macquarie
    ok so i went for a drive for about half an hour or so it reached temp about 80 deg which im happy with but now if i still give it a boot full the temp gauge drops 10 deg then slowly makes its way back to 80 deg ???? this is very confusing still dose this mean my thermostat is getting sucked open???
    i also still have that welch plug in the top radiator hose to slow the flow down and a larger water pump pully.
    any one else got any more ideas i can try???
  4. #24
    Dave
    hmmm a little left field, but how much do you trust your temp guage?
    my VDO temp guage has been playing up recenetly. temp creeps up for no reason, give it a hit with my hand and it jumps back to where its supposed to be.
    - Blaise Pascal
  5. #25
    Jul 2009
    shaun
    nsw
    port macquarie
    I trust it fine I have a thermo gun too I check it with that and it says the same temp give or take a couple of degrees
    So any more ideas cause I'm confused about it
  6. #26
    Member B1FF_86's Avatar
    May 2010
    Anthony
    Patterson Lakes
    what temp is your thermostat ment to open? have you tried putting it in a cup of hot water with a thermometer and seeing if its opening early, it might be as simple as replacing your thermostat,
    My Soon to be Panda CA18DET powered N2 ae86 track car
    http://www.ae86drivingclub.com.au/fo...t-s-white-AE86
  7. #27
    Jul 2009
    shaun
    nsw
    port macquarie
    I'll have to buy a thermometer and check it out that I will try next but I'd say it is fine. Drop the coolant for the hundredth time lol. I will get it right soon enough.
  8. #28
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    Just put water in it until you can figure it out. Wont be ideal, but for the testing period it shoudlnt do any harm (im assumign a shorter testing period).
  9. #29
    Senior Member KE70's Avatar
    Alek
    Lalor
    I had a similar problem with my car(JDM bigport) and it never warmed up, I found out that the thermostat was stuck and not opening fully. This is due to the car sitting around for ages (over a year). I changed the thermostat to a genuine Toyota bypass one , the one on the right from Sam's photo.
    After fixing it and actually driving the car I noticed that it never fully warmed up and always ran cold, so I took off the manual radiator fan and now I drive with nothing there and it stays about 1/3 of the way on the temp gauge.
  10. #30
    Jul 2009
    shaun
    nsw
    port macquarie
    thanks for the help ke70 but i run thermo fans and they dont come on till 92 deg so yeah
  1. car running too cold what the hell
    By slider4life in forum Technical - Questions
    Last Post: 17th June 2010, 10:01 PM
  2. 4age engine's - cant figure out what cars they come in ect
    By nichy in forum Technical - Questions
    Last Post: 18th March 2010, 02:22 PM
  3. Power figure.
    By DAMO46 in forum Technical - Questions
    Last Post: 7th July 2009, 05:13 PM
  4. Easy way to figure out differential gear ratio?
    By Wally in forum Technical - Questions
    Last Post: 23rd December 2008, 07:42 PM
  5. can anyone figure this out?
    By andro0o in forum Offtopic Discussions
    Last Post: 21st August 2007, 04:06 PM
