Results 1 to 10 of 14
Thread: aftermarket camshafts and factory ECU
    Ridgehaven
    Default aftermarket camshafts and factory ECU
    I have a pair of HKS 264-degree/8.1mm lift inlet/exhaust cams (and TRD adjustable sprockets) for my Kouki Bigport.
    I have been told these are fine to run with the factory ECU. Opinions?
    Thanks, Ben.
    Veteran AJPS's Avatar
    Lonsdale
    Given you can make more than cams from an ECU (bullen made 79rwkw) with a computer, I would save up and get a computer and do it all at once.
    To summarise. Buy an ecu.....
    Mt Macedon
    Ages ago a friend threw a set of 272deg cams into an otherwise stock bigport (I think he wrote about it on Toymods.. maybe user "cnic82" or "craigy" about 5 years ago). He said they made a noticable improvement and everything ran fine.
    So yes, you can do it. Of course it's not optimal (as Dave says, tunable ECU will help make the most of them), but it should work.
    Ridgehaven
    Obviously an aftermarket ECU would be ideal, but this is only temporary. Surely the difference will be felt.
    A tuned motor with ECU will be fitted at the end of the year.
    Davey & Riki-lee
    South Australia
    Seaford SA
    With the small cam size it will be alright for now but get a ecu to get the maximum out of them
    Our introduction - Click here
    Gone
    Joel
    Picton
    What Hen said - 264' definatly, and 272's have been done before aswell i think
    Moderator Frak's Avatar
    Jamie
    264 HKS's on stock ecu, sure a/f ratio is not perfect. This was after quite a bit of messing around with cam timing.
    Hachiroku since 1994
    Ridgehaven
    I picked up my set of 264's quite cheap.
    Thanks Frak, that's some really really good results.
    Time to chuck them in and get a tune then
    Dave
    whats with the massive jump of torques from about ~3200rpm?
    TIVS opens up at about 4300 yer? (assuming its a bigport) not that that should make a jump in torques, but its about the only thing i can think of that happends around that RPM.
    good to see some actual data though.
    - Blaise Pascal
    Jamie
    It's the load coming up on the dyno(even tho full throttle when run started, I can explain how this happens if you wish, but bit of writing) so ignore the first part of the curve.(also ignore the hair, it gives no extra power)
  1. Which Aftermarket ECU?
    By JDM-086 in forum Technical - Questions
    Last Post: 11th April 2014, 09:54 PM
  2. WTB - ae86 factory or aftermarket intake setup
    By JDMBenji in forum Cars or Parts Wanted
    Last Post: 1st November 2012, 03:47 PM
  3. ae86 factory or aftermarket undertray
    By cri_ag in forum Cars or Parts Wanted
    Last Post: 13th September 2009, 04:10 PM
  4. aftermarket ecu
    By drftr86 in forum Technical - Questions
    Last Post: 24th March 2008, 12:43 PM
  5. Aftermarket Cams/Camshafts on 20v
    By Wanabe_Garage in forum Technical - Questions
    Last Post: 10th December 2007, 09:21 PM
