Results 1 to 10 of 10
Thread: bosch coils which one's?
    Senior Member J0RD0's Avatar
    Feb 2010
    Jordan
    Default bosch coils which one's?
    Hi all doing a coil pack conversion and need to know which one's to use e.g. part number's. Have spoken to a few dealers and apparently there are a few different types, even though they all look the same some internals are different so ive been told.
    THE EVOROLLA none of this SR shit . . . EVO 7 powered bitches
    https://www.facebook.com/KeConversions
    KE conversions - making your conversion simple
    4AGE CA18 SR20 BEAMS 1UZ to KEXX mounting kits and hydraulic pedal box's available
    Aaron
    In the Mountains
    4g63 doesnt already use coil on plug?
    Veteran Skylar's Avatar
    Ken
    Man, be more specific when asking questions.
    What ECU?
    Is there an ignitor in the system? and do you want to retain it? (dunno if bosch have any coils with ignitors built in or not.)
    Feb 2010
    Jordan
    sorry meant to put that info in. 4G63, Stinger 4424 and a 4 coil ignitor
    Ken
    I don't know why I know this off the top of my head but for simple two wire hook up, the HEC716 is your best bet.
    Try ringing Brennan at Dynotunz. 3800 4940. They do a bit of evo stuff and fit EMS computers. He might
    shed some light on it for you?
    Feb 2010
    Jordan
    cheers andrew and skylar
    Skylar is there any reason why that coil number is the better one? Just curious to know what its got that the other one's dont etc
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    we always use hec716 coils they work well
    AE86 THE BEST
    Ken
    Off the top of my head, that's the one I see used most everywhere. The MEC's aren't really relevant here as you're running sequential, I hope.
    Then I did some digging as i need coils for one car or another. Don't get the 715 as the 1/4" blade terminals are shitty and can jump across or something. It's apparently discontinued or redesigned. Same shit as the HEC716 except 716 has screw on terminals. Better. Then there's the spark energy. Numbers below. 715/716>717/718 There's the 720 and 723 but 1. you don't need that much energy(wicked for use in a stun-gun), 2. it's 'apparently' more than what the microtech box can put out.
    HEC 710 ( 9 220 061 710 ) with 3.5 ms =92mJ ( male anode, minitimer connector rear )
    HEC 715 (9 220 061 715) =92 mJ
    HEC 716 (9 220 061 716)= 92 mJ ( male anode )
    MEC 717 (9 220 061 717)= 70 mJ
    MEC 718 (9 220 061 718)= 70 mJ ( male anode )
    MEC 720 (9 220 061 720)= 115 mJ
    MEC 723 (9 220 061 723)= 121 mJ
    Either that or ditch the ignitor and run ls coils. There's a set of 4 used coils but the HEC716 will be cheaper than that.
    Feb 2010
    Jordan
    HEC716 it is then, thanks guys!
  1. 1NZ/1ZZ coils and 20V motors/igniter/coils
    By 70XIN in forum Technical - Questions
    Last Post: 24th March 2020, 07:44 PM
  2. HELP! bosch 044
    By lach in forum Perth & WA Events and Discussion
    Last Post: 16th June 2012, 12:33 PM
  3. Replies: 19
    Last Post: 24th April 2010, 02:10 PM
  4. Replies: 19
    Last Post: 11th April 2010, 12:48 PM
  5. microtech LT10S X4 IGNITION BOX AMPLIFIER + 4x bosch coils
    By 350hp4agte in forum Car Parts For Sale
    Last Post: 25th March 2009, 08:57 PM
