nope do it the other way round.
put the pressure sensor in the stock location on the block and put the temp sensor in the sump.
i have seen temp sensors used as the sump plug..........just an idea
Car - ke70
motor - 4age smallport
use - dori
problem - run into a bit of a snag with my gauge sensor adapters
personal situation -
can i run my oil temp sensor in the stock position of oil pressure sender and the oil pressure sensor in the sump?
cheers![]()
thanks man
all sorted now. had to mill out the adapter i had with out fucking the threads lol. oil pressure in stock location and temp in smallport stock oil cooler return (sump)
did you get my pm? just waiting on smallport map & lambada sensor in the post now. everything else is done. do i need a lambada sensor cause i do have a big port map sensor... so we could get under way? KEEN AS!!
cheers budday
