Results 1 to 5 of 5
Thread: brake bias, rears locking before front
    Senior Member macca1590's Avatar
    Central Qld
    Default brake bias, rears locking before front
    car - rt142
    motor - 22re (irs and rear disk)
    use - daily ish
    problem - rears lock before fronts
    occurs/started when - since i got it, still dose it with ra65 calipers and rotors on front
    personal situation - check under rear for proportional valve like hiluxs have that is connected to rear suspension in case it was stuck but dose not even have one, so do the have a proportional valve in the master cylinder that may be stuck or blocked or out of adjustment or is it just the difference of the front caliper pistons to the rear caliper pistons that change the proportion from factory? and defiantly is using rears more than fronts under normal conditions too, even only after driving around for a few weeks brake dust it on the rear rims but not front
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    ever thought that the rear lock up first as they have less weight/pressure forcing them to the ground?
    Central Qld
    well yeah thats what bias is for to overcome the fact that there is less weight on the rear
    Central Qld
    might just buy a adjustable valve on ebay 120ish big ones if no one has any ideas
    Glenn
    North Ringwood
    if it was discs all round from the factory, the valve will be on the fire wall ,hiluxes only use the valve at the back for heavy weights ,etc the more weight in the back the more it pushes down on the valve
  1. wilwood brake bias ajuster
    By ae86-13b in forum Cars or Parts Wanted
    Last Post: 11th August 2011, 10:35 AM
  2. Brake Bias Adjuster
    By stouty in forum Technical - Questions
    Last Post: 23rd February 2010, 10:28 AM
  3. brake bias
    By Tim.duncan in forum Technical - Questions
    Last Post: 1st November 2009, 02:21 PM
  4. WTB: brake bias
    By lewwy in forum Cars or Parts Wanted
    Last Post: 3rd October 2007, 01:31 PM
