Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: Ke70 lock diff and Lowering.
    Default Ke70 lock diff and Lowering.
    Yo guys,
    Just wanted to lock up my diff, once i take it out, what do i do from there, Where do i weld?
    Also how bad is it to cut the stock springs done it in one of my old ke70s didnt do much but wreck the tyre cause it needed a wheel aligment.
    Jonathan
Name:	Standard welded diff.jpg
    Is this what you need?
    E-Famous (Remeber your roots)
    As above.
    Would be better putting Falcon springs in it. But it will still be shit.
    Veteran driftke70's Avatar
    Ryan
    Buderim
    i had 3 borgies like that above and smashed all three, got duncan at top cog to fill on to the brim and it is still going today in seeks car.
    wheelfriends.wordpress.com
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Cutting stock springs is pretty poo. I recon a KE70 will handle better with uncut springs than standard cut ones. Because think about it, doesn't stiffen up the car at all, its still just spongy springs except now you've even put the shocks out of their proper effective range(assuming you're still running stock springs too).
    Veteran shift_rook's Avatar
    SE Burbs
    cutting springs does make them stiffer, however it'll make the ride shit, if you can team em up with some short stroke shocks it's a bit better, i still wouldn't recommend it
    yeah,
    All this is tempo anyway, im gonna 4agte it, put coilovers t series etc but for the time being i just wanna have some fun with the 4k.
    my last ke had cut springs and to tell ya the truth it felt like a go cart but i know what ur saying golberg.
    So what do u mean driftke70 just smash it with welds???
    SE Burbs
    just make sure the spider gears aren't going to move round and you'll be sweet, make sure it's a nice strong weld. have you driven a locker before?? definately gonna make the 4k more fun just have to be a but careful in the wet haha
    Veteran driftism's Avatar
    Andrew
    Watsoia
    real men use lockers, LSDs are for posers
    have fun.
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    I agree, id never lock a borgy like that. With such a small amount of weld id be too worried that itll blow up.
    Every time ive had my diff welded, it was done with a block of steel, two bolts and a shitload of weld through the void between the spider gears.
    Ive only ever had two diffs in my car, the first one came out fine and went straight into another ke70... the only damage in my diff is the crown wheel
  1. AJPS KE70/AE71 Lowering Springs!
    By x744 in forum Car Parts For Sale
    Last Post: 3rd August 2012, 11:49 AM
  2. WTB: Lowering blocks for a ke70 wagon
    By juzzo8 in forum Cars or Parts Wanted
    Last Post: 2nd December 2009, 06:30 AM
  3. options for lowering ke70
    By jdm_style in forum Technical - Questions
    Last Post: 5th April 2009, 09:45 PM
