Results 1 to 2 of 2
Thread: throttle position sensor help
    shaun
    Qld
    Logan
    Thumbs up throttle position sensor help
    hey peopled just need a quick tip for setting tps senor. I removed the tps to stick on rear wheel drive manifold now i know you need to use ohm meter and stuff but i cant get the ohm meter to read what ii should be in spec list, but i not 100% sure i am doing it rite. I have done it by ear now with the car idling and i think i found the sweet spot but i know that it not the right way how do all you guys set yours the car starts and runs fine any tips
    Drink & Drive Your A Bloody Idiot Drift & Slide & Your A Bloody Legend
    Veteran biggo's Avatar
    Nick
    Noosa
    Start in the middle and go from there
    or download the manual and do what it says
  1. Throttle position sensor wanted TPS
    By random in forum Cars or Parts Wanted
    Last Post: 14th March 2012, 01:25 PM
  2. Throttle Position Sensor Problems
    By bennyq in forum Technical - Questions
    Last Post: 24th November 2011, 07:19 AM
  3. Throttle Position Sensor (TPS) set up??
    By tetsujin in forum Technical - Questions
    Last Post: 13th August 2008, 08:48 AM
  4. 4age Throttle position switch
    By HRV-00S in forum Cars or Parts Wanted
    Last Post: 2nd November 2007, 09:19 PM
  5. How to get Throttle Position Sensor working ?
    By kimilicous in forum Technical - Questions
    Last Post: 24th June 2006, 12:33 AM
