Results 1 to 5 of 5
Thread: Wilwood Bias Adjuster install
    Senior Member dtour's Avatar
    Jun 2009
    Jon
    Ryde
    Default Wilwood Bias Adjuster install
    Picked up a bias adjuster today and before i go ripping apart my shit i would like a bit of guidance. Ie, what issues i might have? mounting? what lines i have to get.
    I did search for this stuff but all the threads were full of bickering and general shit.
    So i really would prefer that people who have actually installed one of these give input and advice.
    Pics of install and lines would be epic
    Cheers,
    Jon
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    remove your standard rear bias valve, If you have a jap car they are seperate from the front ones, aussie ones are together but you can bypass it pretty easily.
    work out where you want to put the new one (engine bay, interior etc) I put mine on the tunnel next to the handbrake. Putting it in the engine bay where the original one was would be a whole lot easier to fit, but a bit harder to adjust.
    that is mine installed.
    not much more to it, just bleed it through and adjust it up.
    Andy
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    Much the same as mine, but i have mine ontop of the tunnel as the seat wings cover that area:
    Jun 2009
    Jon
    Ryde
    Cheers fellas,
    so im guessing u have to bend up new hard lines?
    Andy
    Adelaide Hills
    yeah, measure past where you want to mount the bias adjuster, and then cut the original one, bend up one half so it goes inside the car, and then you bend up a joining piece and connect it back to the leftover original one, saves trying to bend them up from scratch.
    Andy
  1. wilwood brake bias ajuster
    By ae86-13b in forum Cars or Parts Wanted
    Last Post: 11th August 2011, 10:35 AM
  2. Replies: 10
    Last Post: 28th June 2011, 08:04 PM
  3. Brake Bias Adjuster
    By stouty in forum Technical - Questions
    Last Post: 23rd February 2010, 10:28 AM
  4. Greddy Roll center adjuster
    By Tom86 in forum Technical - Questions
    Last Post: 28th March 2009, 03:00 AM
  5. jaycar air/fuel adjuster
    By eightsixboy in forum Technical - Questions
    Last Post: 19th September 2008, 08:36 AM
