Results 1 to 2 of 2
Thread: Another Stupid Question.... (Weber related)
    Kieran
    Default Another Stupid Question.... (Weber related)
    Car - ke70
    motor - 4ac
    use - fence
    problem - carby isn't bolted in
    occurs/started when - I decided to go in the direction of the weber
    So I bought a weber and adaptor plate put it together and found the studs provided are not long enough to bolt the weber on...Fail
    In the mean time while I was bored I glued it all together with gasket glue. And behold she runs!
    So 2 Questions here:
    a) How long will it last with gasket glue holding it together ? (and yes there is alot of it on there)
    AND
    b) where can I buy longer studs to suit? (note: 1 of the studs needs to be "kinked" to fit through the adaptor plate)
    Stern but now fucked off...
    May 2005
    Nick
    a) not long if you're driving it
    b) I would head to a fastener place.
  1. Stupid Question? Or not?
    By bally in forum Technical - Questions
    Last Post: 10th February 2011, 11:59 PM
  2. stupid question maby but not sure
    By z_brutalis in forum Technical - Questions
    Last Post: 15th August 2010, 03:14 PM
  3. Stupid Diff Question.
    By aaron_drift in forum Technical - Questions
    Last Post: 14th July 2008, 09:15 PM
  4. stupid question... kinda
    By samuek in forum Technical - Questions
    Last Post: 19th April 2008, 07:52 PM
